Blog comment - does not work
edited April 2014 in Hypershot Posts: 19
need help - on my hypershot theme the blog comment does not transmit any comments?
you can write a test but then it writes : "pls. correct your input"? does anyone know what the problem is?
I use the plugin SI Captcha.
THKS for any help!
