Testimonial slider speed
edited February 2015 in Adamant Posts: 7
Hi there,
I am having trouble changing the interval between slides for my testimonial slider. No matter what interval I set, the slider still rotates at the same speed..Is there a setting I am missing?
Thanks in advance for your help.
Cheers,
Ella
    Hello Ella!
    Can You please send me an url to your site?
    Yup sure thing - here it is: http://goo.gl/0LmRAo
    Hi Ella!
    Instead of 'Interval' (time between slides in autoplay mode) use 'Slider speed' parameter (duration of animation).
    Sorry, I think I explained that wrong.. I was meaning I would like the slider to stop on one testimonial for a longer period (around 7 seconds) so that a visitor to the site has more time to read it.
    Changing the interval seems to have no effect, and the 'Slider speed' seems just to slow the transition between slides?
    Thanks for your help!
    Hi Ella!
    You're right! ther's a bug, tiny, nasty bug.
    Stay tuned for Adamant update, I'll let You know when it's ready.
    FYI - new version of Adamant is available to download. Please update, and don't forget to update plugins.
    Great, thank you! Will update the theme and plugins now..
