Hi
My WP version is 4.1.1
and my theme version is the last until this day
I have some problems with the fonts in a blog post.
In admin panel, theme options, tyopgraphy, Font settings for content shows up for the first paragraph.
And the options for first paragraph doesnt apply !
So the problem is that i can not change the typography of the content
please help
thanks
www.lazakatfacile.fr
the article i talk about is :
www.lazakatfacile.fr/calculer-zakat/
your page desing is the reason why You can't see desired effects.
The very first paragraph is used to display an image, and this very paragraph has assigned different font family, but there's no text inside.
You should use first paragraph to display text - then You'll see the effect.
sorry but i didnt understand ?
in Adamant we decided to give to user possibility to define two font families used for displaying content.
First font family is used to display first paragraph of content.
Second font family is used to display other paragraphs of content.
So if You have defined two different font families then the first paragraph of the content will look differently. Simple, right?
In your case it seems not work only because You have placed an image in the first paragraph, and the font family cannot be applied to the image.
And this is the answer to the question marks on the screenshot You made.
