Hello
I have a problem with the visualization of many images and I have no idea why. I know that the problem is not with image’s archives because I load these in other Wordpress, with different theme, and it worked perfectly.
When I add those images in a Work (scroll mode or other) and load this Work on navigator, I can see the previsualization of the images in the page, but if you click in one of them you can see loading animation and then nothing. The lightbox gallery doesn’t load.
In “mywebsite/wp-admin” the theme load right my image’s miniatures, but if you enter in the media-->library and click in those images (Attachment Details) its links appears like broken (but you can see the miniatures in the section Edit Image too).
I’ve tried to:
- Deactivating all plugins
- Different browsers (Firefox, Chrome and IE)
- Uploading the images again.
- Save and uploading other versions of that image from the original archives and the problem persist (like I said, the problem is not the images).
I had some more images with that problem with the theme and I deleted them from my web, but these are indispensables:
1) This Work, all images:
http://www.bizarro-grafico.com/work/packaging-refresco-bitter/You can see that in other theme works perfectly:
http://www.enriquecamina.com/galleries/galeria-prueba/2) This Work, last image of scroll:
http://www.bizarro-grafico.com/work/tarjetas/Sorry about my English.
Your English is very good:-)
I believe it is server issue, and it is caused by non-english characters in file names, like "Bitter-Dia-Diseño-Presentacion" has character "ñ". It encodes them wrong, but I am not sure why only in some cases.
Try in case of this work http://www.bizarro-grafico.com/work/tarjetas/ and this photo http://www.bizarro-grafico.com/wp-content/uploads/2015/03/Tarjeta-Santa-Compaña-Mockup.jpg changing name before uploading it, to "Tarjeta-Santa-Compana-Mockup.jpg"
This should help. I know I had similar topic but with Chinese characters. I will try to find it now.
As Wordpress usually doesn’t give problems with archive’s names (Wordpress change the names with _ for space and things like that automatically when you upload an archive, and in my other page these images works perfectly), I couldn’t imagined that that was the failure, but you are right.
I will be more carefull next time. Thank you very much.
Regards.
