Hi again,
I've been checking and date is not translated in any part of the website.
A little resume... on the website www.italiaamoremio.it the date on post (below footer 2 widget) is not translated to italian.
It's the only thing the website is not translating...
I'm using widget logic, but even deactivating it the problem's still there...
If no date is translated then it sounds like problem is somewhere else. I have found similar topic here https://wpml.org/forums/topic/unable-to-translate-date-format/
Also check this https://wpml.org/forums/topic/date-formatting-issue/
If none will help I will try to do it on your site.
I solved the problem for the month thanks to your links.... I missed the italian .mo files on wp-content/language folder..
Now i do have another problem... :-)
How can I delete the "th" beside the date? :-)
Regards
Gabriele
On your place I would change date format to different. Check Settings->General->Date Format
thansk for your reply... I supposed it was automatic to change date from english to italian... and the "th" would have changed.
Now I coose italian format and I've lost "th" in english, but it's not a problem.. thanks very much for your assistance...
ciao
