Issues with images not being responsive
Hi there,
When viewing the website from our iphone (5s - version 8.1 - using Safari) my images - especially background images - are not responsive. What can I do to fix this?
beta.evolve-group.com
    can You point which area has problematic background image?
  • The background images used on Our Process and Reach Us sections.
    And You would want those background images to shrink? As far as I know - the behavior of those images are ok.
    Both of them have size set by this rule: background-size: cover; which means that whatever the size of this content block is the background image will:
    1. not be deformed
    2. will cover entire content block.
