SSL problems
edited December 2016 in Photon Posts: 48
After installing SSL certificate music was missing, and also it is written that not all site content is protected (all links fixed (images), plugin Filter insecure content SSL didn't help). Please help to solve these problems.
[link removed - author request]
Thank you.
Pavel
    Just can't figure out how to fix these bugs, i have just deleted those images, the error is not passed ( logo has dissapeared).
    537 x 519 - 136K
    Hello there:-)
    I don't have any experience with SSL, but I can try workout something with you.
    So what else beside music doesn't work(links please)?
    Have you disabled music player?
    Music player is on.
    Some links doesn't work. I don't know why theu are loading with js. I checked all the included images, posts, galleries, pages. I can't find the links on them.
    I have deleted some of those iimages and logo has dissapeared.
    Thanks.
    1895 x 805 - 531K
    After i have disabled music and ajax.image
    1886 x 799 - 309K
    I don't experience these issues as not logged user. Do you have any cache plugin installed?
    I don't see music player, and logo is fine.
  • edited October 2016 Posts: 48
    i got cache plugin, but i uninstall it, as i got problems after i had installed site on hosting.
    I loged out. The main problems are the same - there are no music (music is on), and there is js script that generate links without httpS:...
    Post edited by PavelT on
    Yes, but strangely I don't even see music player, like file don't exist anymore. Have you tried to re upload it?
    PavelT said: and there is js script that generate links without httpS
    I have checked code of this file webfontloader and it looks it should load files with https.
    If you like I can debug it on your server.
    Could you please send me temporary access to your FTP so I could check there what is going on? Send it here on forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please attach LINK to topic it applies to.
    After i clear background here, i successed. I got green padlock.
    But i want backgroung here.
    So when i load background here. The code generate link without httpS..
    Can you help me? How i can get background on load...image with htpps.
    1118 x 536 - 175K
    PavelT said: After i clear background here, i successed. I got green padlock.
    Then maybe you want to set solid background for slider element? So you will see background on load.
    Try this custom CSS:
    #a13-slider{
    background-color: #000;
    https problems move to your other topic.
    Air said: Yes, but strangely I don't even see music player, like file don't exist anymore. Have you tried to re upload it?
    Thanks for the advice, it helped.
