Number of grid elements in postgrid for web and mobile
in FatMoon Posts: 136
Hi there!
The postgrid elements the bottom of the page
see here:
http://bumsch.com/work/book-mockup-2/
For web it goes from 4 to 1 grid elements per row.
For mobile its always 1 grid elements per row.
Can I change these settings somewhere?
Thx!
Vincent
  • edited October 2016 Posts: 1,758
    this can be achieved only by altering css styles.
    use definition:
    .vc_col-sm-3 { display: inline-block !important; width: 25% !important; }
    Post edited by surgeon on
    Hi Surgeon,
    That worked brilliantly! Cheers!
    Can you do the same for mobile? it's now on one column.
    I would prefer for it to be on two columns. Would that be possible?
    Kind regards,
    Vincent
    Actually - forget previous - I just emptied the cache on my mobile phone. It does work on four colums.
    Is there any way I could have it on two columns for my mobile phone?
    vncnt said: Is there any way I could have it on two columns for my mobile phone?
    yup!
    you need to wrap css definition in media query
    please refer to: http://www.w3schools.com/css/css_rwd_mediaqueries.asp
    Thanks Surgeon,
    Quite a helpful site.
    I just changed my mind and now I would like the have 3 bricks wide across all media. (web - iPad - mobile)
    Do you have a bit of css for this? I won't change my mind again. Promise. ;)
    Then start with setting it in VC editor, set it to 3 columns, and then add this custom CSS:
    @media only screen and (max-width: 768px) {
    .vc_grid.vc_row .vc_grid-item.vc_col-sm-4 {
    width: 33.3333333%;
    Hi Air,
    Thanks, that works perfectly!
