Hi Fatmoon Support,
I am a photographer and therefore I is crucial for me to get the best possible SEO for my images on my website.
Using another theme I experienced SEO problems when I used image carousel to show my images compared to just inserting images full size - one by one. I know a lot of things can influence SEO... but I think it had something to do with the carousel plugin I used.
So starting with Fatmoon I would like to hear what you recommend to ensure best SEO for images placed in work/portfolio? Does it matter if I place images one by one compared to using e.g. the image grid?
If you have any other recommendations aside from always ensuring alt-tags etc. I would be glad to hear about it.
Thanks in advance,
Martin
As far as we talk about elements from our theme, we know that we did our best to give search engines what they need(according to our knowledge). So albums/works in slider mode or bricks mode should be fully accessible.
However we are still open to suggestions.
As for parts from Visual Composer - I know they trying their best to improve SEO, but I am not sure how they manage access to files when they generate carousels and stuff. I just don't know how it is exactly build.
So I don't have any recommendation except what you already know :-)
Thank your for the answer.
I will ask Visual Composer directly and hope they can provide a bit more clarity. I am sure they are aware of the issues and hope to get an honest answer from them.
All the best,
Martin
