I want bigger social icons than the ones used in the theme and linked them the normal way, but it wants to open up the link as a lighbox for some reason?
Also I want to link a specific word in a paragraph to also link to e.g.
#aboutus but it doesn't want to save it at all?
Can you please assist.
Thank you.
Regards,
Jhorene
thank you for reporting this issue. It'll be fixed in upcomming update.
to force your bigger social icon to work - please edit (in text mode) 'Text block' shortcode that contain this icon, and add to each anchor (which contain image) you don't want to act as lightbox image.
So instead of: you should have: Also you can add class to anchor by clicking on 'image details' while editing 'text block'
(sorry, can't make screenshot of modal window, you can ignore the image i attached)
second thing: for now you can't write your own jQuery functionalities, so there's only one way to achieve this:
edit the paragraph in text mode, wrap entire achor with some html tag that has 'scroll-to' class, like:
