Hi I bought this theme and I like
I have some questions:
1.-How to make the magnifying glass to display the image and enlarge it, then disappearing in the upper?
http://img577.imageshack.us/img577/7970/hivk.jpg2. – The first image in the blog posts, the image quality is lost a little (woman with roses in the head), this is so, how can this be fixed?
http://img163.imageshack.us/img163/4674/yz3w.jpgWaiting for your reply, greetings and very good theme
My page :
http://marcoescobedo.com/
1. In settings of theme in Airlock-> Portfolio -> Icons on portfolio item you have to set it to Automatic.
2. Not much can be done as TimThumb script will have to resize every image to make it fit. I can search for its quality settings if you need, but changing this can make images bigger in file size.
I can tell you that if you wouldn't mention it, I wouldn't see its lower quality. That is how it is - such things can see only author:-)
I have reviewed in Portfolio / automatic dialing. In my page does not appear on the magnifying glass. Solution for this?. Nor will darken the whole figure, dark above, the text area is not dark.
http://img837.imageshack.us/img837/4558/pm3h.jpg
http://img541.imageshack.us/img541/9769/dw7k.jpg
greetings
http://img710.imageshack.us/img710/438/hbd3.jpg
Now I see you have JavaScript error, so this patch should help.
http://img571.imageshack.us/img571/4411/utmx.jpg
As the lens is activated?
Sample page:
http://itp.nyu.edu/~ssb425/blog/
Greetings
I can see that now more things are working on your page thanks to patch:-)
To get lens image you have to fill first fieldset in Portfolio details - Add Image and videos in each portfolio item.
A question. You can delete or hide the image that appears in the publication (portfolio).
Or Maybe by clicking on the icon nuts function as link to another page.
thank you very much for your support all much better
I uploaded 15 images,
Portfolio items displayed = 12
Icons Appear "<>".
Click on icon ">" to see images 13,14 and 15, then 404 error message appear.
How to run icon, to see the images 13, 14 and 15 ?
Thanks for reading and answering
About hiding image in portfolio - this part is designed to show even more images of your portfolio item, so there is no easy way to hide it. If you don't want to see images in any portfolio item, then I can help you edit code :-)
For second issue, try setting permalinks - Go to Settings->Permalinks and set them to post name
