Top-Level Navigation Anchor Links Inactive
edited July 2014 in Adamant Posts: 7
How can I make the top-level navigation anchor links active (clickable) when they have child items in the dropdown?
    Hello Michael,
    thank you very much for this report, this bug will be fixed in upcomming update.
    For now you can fix it by editing scripts.js file located in wp-content/themes/adamant/js/ folder.
    Find this line:
    if( jQuery(this).parent().hasClass('scroll-to') && jQuery(this).parent().hasClass('menu-item-has-children') && !jQuery(this).parent().find('.sub-menu, ul.children').hasClass('open') ){
    and replace it with this line:
    if( jQuery(this).parent().hasClass('scroll-to') && jQuery(this).parent().hasClass('menu-item-has-children') && !jQuery(this).parent().find('.sub-menu, ul.children').hasClass('open') && !jQuery(this).parent().hasClass('hovered') ){
    please be careful, and make sure that you've copied whole line.
    FYI - new update is available, top level menu items work as they are supposed to.
