hello
i've install hypershot onto a recent wordpress.. on a dedicated server,
all parameters have not been change at all
tonight i've got a big alert of spam detection came from my ip adress, i know this come from this new install of theme.. i also had another spam problem since i've installed another themes...
how to fix it?
thanks
1. I don't quite understand how this is connected to theme, and how you found out it is cause of theme.
You also say that you had another spam problem cause of other themes.
You have to explain it to me. 2. Hmmm, if I knew that something like this is happening I would fix it in theme update. So I don't have any solution for you, as I don't have any reports about such cases.
3. And what are these "big alert of spam detection"? Can you explain in further?
If it is all connected to contact form and comments form then just install captcha plugin http://apollo13.eu/docs/hypershot/#!/plugins_recomendations_captcha as hypershot is prepared for it:-)
i'll install install it again
and see.. i'll get in otuch about it
