I'm wondering if it's possible to load specific posts the same way the custom post type work are loaded.
I need a custom overlay with links etc for works so I made new grid element template. But I can't find a way to load them in a lightbox.
Thanks in advance.
do You have working example that You can show, whatever the stage of developement?
It gonna be easier to talk about your case if You have already something done.
