Grid element builder does not work in VC
in Blame Posts: 29
When into my grid element builder and add a custom field. The pop-up settings box gives me the following fatal error :
Catchable fatal error: Argument 1 passed to Vc_Edit_Form_Fields::setSettings() must be of the type array, null given, called in /home/micdri10/EXTREMESOUTHAMERICA.COM/wp-content/plugins/js_composer/include/classes/editors/class-vc-edit-form-fields.php on line 47 and defined in /home/micdri10/EXTREMESOUTHAMERICA.COM/wp-content/plugins/js_composer/include/classes/editors/class-vc-edit-form-fields.php on line 68
    Isn't this thing connected to your other topic http://support.apollo13.eu/discussion/3193/warning-in-regards-to-formatting-php#latest ?
    It might also be issue of VC. Have you tested this with default Wordpress theme?
    I found same issue here http://codecanyon.net/item/visual-composer-page-builder-for-wordpress/242431/comments?page=361#comment_9270778
    This one I do not believe is related to the other topic I posted on here. It does not seem to be conflicting with my other plugins. Yea it does look like the same issue on codecanyon. That was a comment though that is 3 months old, so it must not be a product wide problem. Do you have access to look, or ask how they resolved that person's issue?
    edited June 2015 Posts: 10,970
    jkellerer said: Do you have access to look, or ask how they resolved that person's issue?
    Unfortunately not, they don't have open forum like we. That sux.
    I have found few people reporting this issue, like here for example http://support.vibethemes.com/support/discussions/topics/1000059118
    and next here http://allindiachannel.com/how-to-update-visual-composer-in-news-paper-wordpress-theme/
    Does VC work when you switch off debug mode?
    You are talking about the config file debug mode correct? No there is no difference in how it acts if it is set to true or false. Any other suggestions? I am sort of stuck at the moment with this. I have determined it does not have to do with any of the active plugins/themes. That last post seem to indicate it might have to do with a conflict in the database?
    Yes, I was talking about this debug mode.
    In that case this is clearly Visual Composer issue. Let me take a look in their code, and see if I can propose any patch for you, before they fix their plugin. I will reply soon.
    For now I found out that on two almost same installations I have this bug on one but not on other. I will try to find who and what is doing it.
    OK I found it. It you deselect all options in VC then bug don't show up - check screenimage
    Hope this also work for you.
    1811 x 825 - 117K
    That works great! Thank you so much for finding that bug! It resolved all the post grid issues.
