Problem with modal window
in Chillout Posts: 15
Hi, I have a problem with the modal window. When the window appears moves down as shown in the figure, this is due to ??
I awati your answer, thanks
1366 x 768 - 206K
    Please post me an url to your website.
    Thank You for the report, this bug will be fixed ASAP. Please stay tuned few days, I'll inform You when the update is ready.
    Hi Surgeon / angela , it work for us, in file script.js of plugin chillout
    just change in all file for tmp_h outerHeight() for height ()
    and for block scroll range just round values because firefox bug with value 99.99999
    exemple
    var tmp_h = $(".work_slide").find('.'+post_type+'_slide_content_wrapper').height();
    window.A13P.set_scroll_range( (Math.round($('#work_modal_port').offset().top)), (Math.round($('#work_modal_port').offset().top + tmp_h)) );
    hope its ok.
    Nevertheless the update will be released.
    New version of Chillout is available to download from ThemeForest. Addressed issue has been resolved.
  • edited June 2015 Posts: 15
    The problem persist with update. Other solution??
    My version to wordpress is 4.2.2
    Post edited by angela on
    Zendbdc not work with either your solution
    Hello.
    In changelog (http://www.apollo13.eu/changelog/chillout/index.html) there's a info:
    ***=== NEED TO UPDATE 'Visual Composer extend by Apollo13 for Chillout' PLUGIN ===***
    ***=== NEED TO UPDATE 'Chillout Plugin' PLUGIN ===***
    Please update those plugins, the issue You've reported is fixed.
    ok Thanks its work's, but in the section works the modal window don't appears, I need to configure anything else??
    Edit the home page, find 'Works list' shortcode, edit it and set 'Link target' parameter to 'To modal window'
