hi,
1: i have a problem with navigation anchors, when i go appearance-menus- there is no nav anchors just page, custom links and categories..im trying to do one page site...! plus, how can i change background of menu in header??
2. i cant change colors or fonts on site?
3. preloader doesn't work!!
i haven't changed anything in codes, so maybe installation is done wrong??
www.volumen.org
I can see that You have no user.css file, which is supposed to be generated each time You change setting in Chillout Options panel.
Did You make any changes in this panel?
http://www.apollo13.eu/docs/chillout/#!/installation_update_after_installation
and about navigation anchors, i read that, and followed every step but this is what i see
This could be also a problem with your server trying to access 'user' folder which is located inside 'chillout' folder.
If You send me the login credentials (only via private message) then I'll take a look.
