Please can you let me know the default theme settings for Woo Commerce Product sizes and can you give me any recommendations for compatible landscape sizes for your theme.
I have screwed default settings up trying to make my Landscape images look good in Product display and I know longer have the blinds dropping down and it also looks awful.
Many thanks Simon
Default settings are: However after changing sizes of thumbnails you have to rebuild thumbnails, and then you can tell if it looks bad or not:-)
Here are instructions how to use it http://apollo13.eu/docs/fame/#!/plugins_recommendations_rebuliding_thumbnails
Please try it.
Many thanks Simon
Kindly Simon
So I don't know now what is solved and what not so I will ask and answer everything. I don't know what you mean by this exactly. Could you explain with screen shot or something what are " blinds dropping down"? How you discovered it is not compatible? We are using it on our site and it works very fine. It shouldn't be issue in your case also.
There are a lot of free plugins for right click protection https://www.google.com/search?q=wordpress+right+click+protection&ie=utf-8&oe=utf-8&gws_rd=cr&ei=FcpeVqyAN8TMyAPss7yIDA
Thanks for all your kindness:)
Have a good day!
Below in the centre is what call a Blind. Where can i change the effects in albums as per your demo Album pages. ?
Kindly Simon
OK so you ask about shop first and now about album. I am lost :-)
About shop - please show me live link to your site then I can try to check why hovers don't work in your shop.
About effects in album- you can change them in each album by editing it. See options of album http://apollo13.eu/docs/photon/#!/add_new_album
