Albums don´t load up correctly (lazy load problem?)
I´m currently working on my new portfolio and after the new Wordpress 4.4.1 update my sites albums show up weird. I have updated the theme and all the plugins. Wordpress is fairly new to me.
Everything was fine before Wordpress update. So the problem seems to be that lazy load doesn´t load new images but keeps loading the same 10 images. There should be 16 albums. It just keeps loading the same albums and not the new ones. Also if you filter the Albums, it just keeps loading the same images over and over again.
Heres my unfinished site: www.tuomasmustonen.com
Can you please help me?
Regards,
Tuomas
    It looks that something changed in Wordpress and I don't think I will be able to fix it easily.
    For now switch to default permalinks(screen shot), as it looks it solve problem of pagination in albums list.
    Problem is that this http://www.tuomasmustonen.com/page/2/ which should return only albums from second page, got rewritten and leads to first page, so it is endless loop.
    If you switch off lazy load for albums list, and just have pagination you will encounter same problem.
    I will search for solution.
    849 x 660 - 51K
    edited January 2016 Posts: 10,970
    Just FYI - pagination problems are common in WP 4.4. It looks they broke something.
    Type "wordpress 4.4 pagination broken" in google for more info.
    It got broken in WP 4.4.1 and It will be fixed in WP 4.4.2 https://core.trac.wordpress.org/ticket/35344
