Row ID and Navigation Problem
in Xpert Posts: 3
Hello, i change portfolio page name with SOLUTIONS and i entered a row id #Solutions. It worked on navigation slider but didn't work on mobile navigation. I think, it don't designate new id. What can i do?
    we designed our own way to define content blocks.
    please refer to: http://www.apollo13.eu/docs/xpert/#!/adding_nava and http://www.apollo13.eu/docs/xpert/#!/page_design
    Firstly, thank you for your answer but i read this page before writing there. I know little English. Can you write detailed solution for me ? I'm attactign pictures about my problem.
    1666 x 714 - 106K
    1667 x 718 - 110K
    1176 x 665 - 102K
    You don't need to put anything in 'Row ID', just pick a 'Navigation Anchor', You can use the old one - used in previous 'Portfoilio' section. You can post me an url to your website - I'll take a look at it. If you don't want to make it public - send me a private message.
    Thanks a lot. I'm writing pm.
