Hello.
I had a problem with the update the thirteen theme by the wp-admin panel. So I uploaded it via FTP. After that I got this warning Warning - directory /var/www/levslutsky/data/www/test.levslutsky.com/wp-content/themes/thirteen/user is not writable.
As well I was unable to update the WPBakery Visual Composer plugin. I tried to deactivate him but cannot upload.
Before theme installation, i have not able to upload plugins via wp-admin as well and did using FTP.
Can I ask you for any suggestion how to solve the issue?
Before the installation, i made a backup.
http://test.levslutsky.com/
About updating WPBakery Visual Composer - please disable it before proceeding with update it by admin Panel, cause VC has some update mechanism that block updates from theme - annoying I know :-)
If that is still not the case then do it by FTP as usual.
Good luck!
If some of embeded plugins fails on install you can go to thirteen/advanced/plugins and install every plugin(zip file) from there manually, by wordpress panel http://codex.wordpress.org/Managing_Plugins#Installing_Plugins
