hi guys i talk to you on envato and was told to seek help here. For quite some time my VC didnt worked properly, well it didnt worked at all. Than you said to update the theme to the latest version but that didnt helped either.
Not only the VC isnt working but if you look at the Journal blok on my site (
http://webdesignbubble.co.uk/#a13_Blog); you will see that the list of blog posts appeares just fine but if you try to open one the theme gets stock loading....
Please help with tis issues.
I need to update my portfolio desperately...
Thaks
Regards
I can see that you have latest CeeVee and WordPress Core versions.
But Visual Composer is in 4.4.4 version, which is obsolete.
True - automatic update of this plugin is impossible from this version (due to some plugins bugs), but you can do it manually.
The package is here: '..\wp-content\themes\ceevee\inc\plugins\js_composer.zip'
copy it and unzip in folder '..\wp-content\plugins\' - this will overwrite old version.
If you will have any problem doing so - please provide me FTP credentials in private message.
