The portfolio does not work on mobile devices ? Can you please help me fix this as I have not made any changes or anything the theme has come like that. Also I do not see the logo on the slider? But I see the logo no desktop version, please help me as soon as possible thanks.
I have just checked your portfolio on few devices and it works fine. Be sure to clear cache, cause as I see you have minified all CSS on your page.
About logo, yes it is no visible. There is a chance that you have only enabled it for big devices.
You will have to adjust it for smaller devices.
Yes, like Air wrote your logo is our of the screen on the differents views.
Please follow these steps to fix it:
1) http://nimb.ws/jScmkg - you must align your logo to center
2) http://nimb.ws/2GiEfL - switch align to "Grid Based"
3) http://nimb.ws/B2s4VE - switch between views and check where it is not centered and if in some views is not, then correct it by moving to center.
I hope it helps.
With Regards
