Hey!
Rethorical one - do I understand correctly, that via WP I manage content only and via Appearance-Costumize I manage the looks?
Also, please, see the questions in the image. I have a nasty gap from the side I want to get rid of, move the links from the middle to the left side [like in olafsosh.com for reference] and another question there...
Also I managed to import a font into posts [Oswald], but where can I change the font of the menus?
Thankyou-thankyou-thankyou!
OK, Image:
1. Menu links to right: Appearance → Customize → Header Settings → Type, variant, background → Variant → One line, logo on side
2. Side gap : Use such custom CSS: 3. Meta data: Appearance → Customize → Blog Settings → Single post → Post meta: *
Disable options you don't need.
The first question, though: I can change to "One line, logo on side", but the "Publish" button stays greyed out. Also, if I exit the Customize and re-enter it - the old option with Menu Centered is back
AAAAND that one: I managed to import a font into posts [Oswald], but where can I change the font of the menus?
Also it looks like I cannot get rid of that "All / Categorized" thing [see pic]
Here http://rifetheme.com/apollo13-framework/docs/customizing-the-theme/general-settings/fonts-settings/ Font for top nav menu
This is probably filter for blog. You can disable it Appearance → Customize → Blog Settings → Posts list – filter
Thank you, kind sir!
I am sorry, I will have a loot of questions Should I make a separate threads for them?
And the next winner is: I could swear, I already saw it somewhere, but no neither mine or google search helps: where can I adjust the padding and push content downwards, as mo it is under Menu
If the image isn't sufficient, feel free to visit temp domain: http://sekta.area.lv/blog
To push bricks under theme header go to Appearance → Customize → Blog Settings → Posts list → Hide content under header and switch it to Turn it off.
