.item-image:hover a::before, .item-image:hover a::after{ opacity: 0; }
.item-image a { overflow: hidden; } .item-image a > img{ -webkit-transform: scale(1.05); -ms-transform: scale(1.05); transform: scale(1.05); -webkit-transition: -webkit-transform .5s; transition: transform .5s; } .item-image:hover a > img{ -webkit-transform: scale(1); -ms-transform: scale(1); transform: scale(1); }
Could you show me link to that, so I could understand what you mean exactly?
When you hover over, they darken and get that Plus symbol. I would love to have them that "Drop" effect as in albums, if possible, but that's secondary.
Hover effects definitely should be added to blog also :-) But they are not yet there.
If you want to remove this, use this custom CSS: For drop effect try this custom CSS: Hope it helps!
