I have stalled the FAT Moon Theme with all required Plugin with Demo Content. All is working but after install
show message
This theme requires the following plugin: Apollo13 Framework Extensions.
The plugin a13_framework_cpt/a13_framework_cpt.php has been deactivated due to an error: Plugin file does not exist.
Looking your support and suggestion to active the 'Apollo13 Framework Extensions.'
Although I have updated but does not work.
** I need to add 'Individual Album' inside of text with the shortcode (not a list).
Lookin your support
Best regards
Siraj
Thanks for your message. It is strange that you faced this issue, but it also explains some things that was mysterious for me since yesterday.
We have released this plugin to WordPress official repository yesterday, and even it has different slug then one bundled in theme, somehow WordPress recognized it is the same plugin. And now it requires & installs 2 versions.
Anyway try to remove this plugin and then reinstall it again. There is a chance that in the end you will have 2 versions installed: 1.1.3 & 1.1.4. Activate both of them: firstly 1.1.3, then 1.1.4(if you have it also).
Other solution is to keep only version 1.1.4, and don't worry about notice in admin.
However don't worry about it for now - we will fix it with next update of theme.
If this will not help, I will take a look at your installation.
** Please guide me, how can I add an 'Album' in my post with a 'shortcode'?
I could not get any section to get and or use of the shortcode. I read your document ( guide), there is no mention of details as well.
Best regards
Siraj
javascript:void(0);
If you click Activate again it should work, as this error shows, cause WordPress deleted old plugin and didn't notice that there was file name change in new version. Sorry for all confusion about this.
It would be best to talk about it in separate topic, as this is different case :-) Anyway: what you want do exactly?
If you want to add new Album like such for example https://rifetheme.com/cropps/album/fullscreen/ then you should follow this instruction on creating albums http://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/adding-new-album/
If however you just want to add slider from Albums images to your post page, like here https://rifetheme.com/cropps/ then you add such slider with shortcode like explained here http://rifetheme.com/apollo13-framework/docs/content-management/shortcodes/slider/
If this still not what you want, please give me more details :-)
Please activate Apollo13 Framework Extensions or you will not be able to do any of above.
