'Close mobile menu after click' does not work
edited May 2018 in Rife Posts: 17
I've created a onpage website within the Chillout II theme. Everything works fine, however, the 'Close mobile menu after click' option does not work. That is, after selecting a menu item on the mobile website the menu does not close but has to be closed by another click on the 'X'.
Does anyone have an idea how to fix this?
Thank you in advance!
331 x 140 - 8K
Post edited by KleinesPony on
    Hey there:-)
    I have just tested and it works on my installations, so I suspect it can be something in your installation. Could you send me a link to your site?
    Thanks a lot for your reply! This is my site:
    http://35.204.51.56
    I thought it could as well be connected to the tested device but it's not working on iOS device nor in the emulated mobile view.
    Hey again :-)
    I believe it can be caused by one of your plugins, as I see it also is attaching events to this menu items and might be blocking theme events.
    Probably jquery smooth scroll, but not 100% sure.
    The theme has built-in smooth scroll so it might come in conflict. If it is not this, try disabling other plugins.
    Hey, that solved it :)). Would't have found this solution by myself.
    Thanks a lot!!
