Hey!
1. I got communicate from YOAST that my site cannot be indexed by internet browsers. It seems that it is some usual problem with plugin, not theme, but there is some procedure including Google's mobile friendly test and i got that result:
https://search.google.com/test/mobile-friendly?utm_source=mft&utm_medium=redirect&utm_campaign=mft-redirect&id=A5fj_pz2QT7VlOAfDerzBQ&view=fetch-infoLike there are some assets that cannot be loaded by Google bot.
2. I have some problems with translating Photoproof to polish. Mostly it is ok, i read some topics here about translating and docummentation, i installed potedit, went to language folder of theme, found photoproof.po, editet it, saved as pl_PL and... there is no change on my website. I want change "read more" and "prev - next article" into polish. I tried saving it at original name and that also didnt worked.
I dont see there any *.mo file.
3. Is there any option to COMPLETLY remove emoticons from wordpress? I found some ways, but it only changes emoticons from more modern to old and ugly ones. Problem is, that they are still there. I dont wanna them. I would prefer just pure text emoticons.
4. Can i somehow delete hidden sidebar? I dont think i need it.
5. Photos in main page album (www.sztukaportretu.pl) are enlarged. At least vertical ones. Horizontal looks fine. Can i somehow force script to not enlarge photos, but keep them at original size or fit them to screen?
Thanks for great theme,
Przemek
If you have more then one case to talk about then please add every case in a separate topic(read more here), cause if this topic will have more then 3 answers, it will make chaos by answering to different points of the first question. I believe you can imagine this :-)
Back to questions:
Hard to say what could be the reason. I have been on your site, and It looks fine in console.
I also don't have much experience with this tools errors.
You have to have pl_PL.mo file. It is generated by Poedit on save. Original file that you edited has extension .pot no .po
In Poedit you need to go to File -> New From POT/PO file... - this will start process of creating transaltion from .pot file.
https://rifetheme.com/apollo13-framework/docs/translations/translating-theme/
Try this article https://www.hongkiat.com/blog/disable-wordpress-emoticons/
There should be some way to do it, but it is general WordPress question so if this will not help you then try official WordPress support https://wordpress.org/support/view/all-topics/
Sure, just remove its widgets, and it will disappear https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/general-settings/hidden-sidebar/
It is not possible. Photos are set to cover the whole area of parallax, cause otherwise it would create "black bars". I don't have any idea for a solution that would work and look good for scroller with original photos. If you want to have images in original sizes it can be achieved in a slider.
https://rifetheme.com/apollo13-framework/docs/content-management/albums-works-post-types/album-options/
Ufff. Hope this helps ;-)
