Problem with cron job and works
Apparently there is a common problem with planned posts and Wordpress cron job. So there are many plugins to trigger cron so the planned posts won't be missed. The problem is it does it only with posts. Do you have an idea of a line I could add so it would trigger cron job for works ? Cause every work planned since 3 days have been missed.
Thank you !
Sophie
    Yes, I have heard about this issues with Cron not publishing posts. However, I didn't know it is a different thing for custom post types.
    What plugin do you use currently for posts failed publishing?
    Maybe I can talk with its developer about this, and how to approach it.
  • Well, actually, I don't use any, but if I had to use one, I would use this one : https://github.com/sLaNGjI/wp-missed-schedule
    Thank you for caring about that ! :)
    Hey Sophie.
    I have tried to investigate this topic further and I didn't find any info about :
    contentologue said: he problem is it does it only with posts.
    Could you tell me, where did you find such info?
    PS. I have scheduled work, and I will see how it will go, and what can be done to reactivate it in case of failure.
  • I have finally set the cron plugin, and it's working fine for the moment. :)
