I have an image with a dark background for the landing. I have 4 versions of my logo. 2 large in negative and positive (for dark or light background) and 2 smaller slightly different for the sticky header overwrites. Is there an option to specify that to use where. I have to have the negative used when the page lands but I need to use the positive when the background is white.
check site here:
http://ah1dnrtkz.preview.infomaniak.website
Do you mean to switch "header color variant" while scrolling your page, depending on the background color of the section? We don't have such thing currently, as we would have to modify Elementor section element for this.
If instead, you ask to change header variant depending on the page, then sure you can do it by Pages options(Header tab) https://rifetheme.com/help/docs/content-management/pages/pages-options/
