Hi
My website is here:
https://www.lwarwick.co.uk/A number of my images on my main slider are landscape, with the couples on the edges, which is part of my style for portrait work.
The issue is, when you look at it on a mobile, you can only see the centre of the image. I've tried playing with the "Fit images" section on the Edit Album section but it doesn't quite do what I want.
Is there any way of opening a different slider for mobile/desktop? Or is there an easier solution that I'm not seeing?
Luke
If you want images to be always fully visible, you should use the option "Fit always".
Sure you will have then "black bars" depending on the screen your site is viewed at. There is none, but it is an interesting idea to expand in the future.
