Mobile Responsive Problem
edited January 2013 in Hypershot Posts: 4
There is an extra padding to the right of the masonry blog section when viewing it on mobile. The single post view is fine.
Is there a way to fix this for now?
450 x 790 - 97K
    Hello there.
    You could set bricks width to lower value for now. I will work on it and make it more responsive in next update that I am working on right now.
    Thanks for reporting!
    Hypershot 1.1 is available. Please check if it fixes your issue.
