Collapse Accordion
edited May 2013 in Skyfashion Posts: 10
I'm trying to collapse all items in an accordion. It seems that the first item is expanded by default but I want everything to be collapsed. Any way to do this?
    Hi kucholtz,
    Please send me link to page with that issue.
    With regards
    This functionality isn't available normally in our theme.
    If you want to callapse all elements in accordion edit file common/js/scripts.js.
    In line 100 you have a definition of accordion. Delete this lines from your file:
      $(".acc_content").hide();
        $(".acc_title:first").addClass("active_acc menu_line_top link_hover");
        $(".acc_content:first").show();
        $(".acc_title").click(function () {
            $(".acc_title").removeClass("active_acc  menu_line_top link_hover"); //Remove any "active" class
            $(this).addClass("active_acc  menu_line_top link_hover"); //Add "active" class to selected tab
            $(".acc_content").hide(); //Hide all tab content
            var activeTab = $(this).parent(); //Find the rel attribute value to identify the active tab + content
            activeTab = $(activeTab).children(".acc_content"); //Fade in the active content
            $(activeTab).fadeIn();
            return false;
    Let me know if it works for you
    With regards
  • I am trying to collapse all elements as above, is this the same way you would do it now?
    I believe it should work. Just make backup of file you wish to edit, and give it a try.
  • Just to confirm, you are referring to the wordpress/wp-content/themes/ceevee/js/scripts.js file, correct?
    there nothing similar to this bit of code, I must have the wrong file location, can you please clarify?
    thanks!
    You wrote in Skyfashion theme topic. You will have to start new topic in CeeVee category, so developer of this theme will answer you. Sorry, I couldn't know :-)
  • :-) oppss I just searched on key word, didn't notice the theme
    thanks!
