Pictures not showing up in IE
in Blame Posts: 8
Picture son the homepage of http://www.myclientshowcase.com/veeonthevine/ do not show up, but pictures show up on Firefox and Chrome. The links are active where pictures should be. Is there something different in how the theme handles pictures in IE versus other browsers? Thank you.
    What version of IE, cause I have just checked IE 11 and your site works fine.
    I'm using IE 10
    Still on IE 10 I don't see any issues. Can you show on screen shot what do you see?
    I have checked with a friend who has IE11 and the pictures on the home page do not show up with the animation.
    This is what the home page should look like (from Firefox)
    1582 x 604 - 155K
    1498 x 671 - 156K
    OK, now I know what you mean. You have JS error on your site, that is why it isn't animating. Try disabling plugins, to see if it isn't any of your plugins breaking site(it is usually the case).
    Screenshots from home page using IE 10. No pictures.
    1684 x 807 - 112K
    1781 x 769 - 99K
    Thank you for your help. It was a setting JetPack, but not sure which one since i deactivated them all and activated only the ones i needed.
    That is great to hear :-)
