Remove border around text where logo would normally be
Is there any way I can remove this border/outline? I opted for the site title text rather than a logo because I was having a hard time making it retina friendly.
  • edited December 2015 Posts: 23
    Btw, the border doesn't appear in Firefox. Just Safari and Chrome.
    Post edited by JAUTERY00 on
  • Also, can I make it just one line of text instead of two? Sorry about the nit-picking.
    Live link would help when you ask about such things, as I can only suspect what is causing border in your case.
    If you want text to not break, then try using   instead of real spaces between words.
    OK I found link to your site. I see you are now using alt text of image, so it is not text logo, but image, and this gives border.
    If you want text logo try this http://support.apollo13.eu/discussion/919/change-logo-for-text
    As for Retina logo then indeed Hypershot don't have such option, but I did such trick once for someone here http://support.apollo13.eu/discussion/3437/logo-retina
