Full width
Hi there
How do you ensure that the website page is full width and not centered?
    davidrabee123 said: How do you ensure that the website page is full width
    Just use rows with 'Full width' and 'Full width content' parameters turned on.
    davidrabee123 said: and not centered?
    Some shortcodes (like Title, Title with separator) are equipped with parameter that allows to set alignment.
    But if You want to have more control over content blocks alignment - just divide the row into several columns and use only those on the left or on the right side.
  • Thanks but I made sure 'full width' was selected and the whole page still looks like the attached file
    any ideas how to solve?
    1210 x 708 - 68K
    Can You please post me an url to your website?
    I think I'm know what's wrong, but need to be sure. There's a small glitch in last update, we'll fix this ASAP.
  • www.creationsbyeddie.co.uk
    Yep, confirmed, it's a glitch, we'll release a bug fix soon.
    For now: go to Adamant Options >> Custom style and paste these definitions:
    .a13_row_container.a13_full-row, .a13_row_container.a13_full-row.a13_full-content .wpb_row {
      max-width: none !important;
    .a13_row_container.a13_full-row .wpb_row {
      margin: 0 auto;
      max-width: 1080px !important;
    .wpb_column.vc_column_container.vc_col-sm-12 {
      padding-left: 0!important;
      padding-right: 0!important;
  • Hi there
    Did I do something wrong? Doesn't seem to be working
    1443 x 1219 - 231K
    No, You did it correctly, just clear browser cache.
  • Hi there, apologies but I cleared the browser cache and it's still not working :(
    Which element of the page indicates that You were not successful?
  • Thanks
    It's really the first image at the top, cant seem to cover more than the central alignment
    http://creationsbyeddie.co.uk/
    Ok, as I thought. This image is displayed just like You set it.
    Tell me what's your goal or send a blueprint of it.
  • Thanks
    I want it to be the size of the attached
    1864 x 1274 - 4M
    ok, set the first row as 'full width' and 'full width content' and place this image into background with cover parameter.
    Or:
    set the first row as 'full width' and 'full width content' AND resize this image.
  • Perfect thanks so much
  • Thanks so much for all your help
    Really like this layout (attached). One last thing, is there an easy way of overlaying text over images like they have?
    1922 x 1146 - 4M
    davidrabee123 said: One last thing, is there an easy way of overlaying text over images like they have?
    Yes. Put the image into background and design text with shortcodes 'Text block' and/or 'Custom Header'.
  • Thanks, problem I'm having is that the background doesn't adjust to mobile. If you look at virtualwalkthrough.com and scroll down to the bottom, the image doesn't scale to the mobile screen
    It is scaling down, it is set to cover entire row and it does so.
    If You want to see entire image that is put into background - set it to 'contain'
  • Appreciated
    Sorry can't find the contain button, where is it?
    ok,
    edit row You want to change, give it an extra class 'bg_img_contain'
    then go to Adamant Options >> Custom Style and paste this definition:
    .bg_img_contain {
      background-size: contain;
  • Unfortunately didn't seem to work, not sure why. Thanks for all your help
    Send me via private message login credentials to admin panel of http://creationsbyeddie.co.uk/ and write exactly which image and which row You want to modify, and how You want it to look.
