"Load More" button doesn't work
in Xpert Posts: 3
Hey guys,
apparently I have the same problem as mentioned in this thread:
http://support.apollo13.eu/discussion/3742/load-more-buttem-don-t-work/.
The "Load More" button on my portfolio and blog page doesn't work at all.
And I already added some custom styles to fix the buttons design:
.post-content .a13-button {
   width: 120px;
.post-content .a13-button i.vc_btn3-icon {
   display: none;
   position: relative;
.post-content .a13-button .vc_btn3-icon-left {
   padding-left: inherit !important;
.a13-button .hover a, .a13-button .normal a {
   background-color: transparent !important;
   color: #5472d2 !important;
/* custom style that has nothing to do with the load-more-button */
.post_slide_content_wrapper #dsq-app2 {
    margin-top: 25px;
Currently using WordPress 4.4.2, with version 1.2.3 of Xpert, and the following active plugins:
Problem occurs on the following pages:
Thanks for your help :-)
Regards,
Eggerd
    thank You for this report, I'll fix that ASAP and release an update.
    Please stay tuned.
    The update is ready, please download it and update your wordpress. the problems are solved.
    Hey, thanks a lot - now it's working like intended.
