WPML Flags
I've put the WPML chooser in the top menu. Works great but it's not showing the flags.
I've put it into "custom info 3" at Header Top Bar.
<?php do_action('wipml_add-language_selector');?>
Any changes recommended to show the flags?
Thanks,
Paul
    I have just marked flags to show in WPML settings and they show up. See this:
    1160 x 226 - 18K
    707 x 147 - 8K
  • Hmm. Not with my site: www.cosignnv.com, but it's on another location. I'll try to add it on the right side to the menu.
  • Hi, actually it's much better after the menu. However the old one is still visible.
    I thought it was on that location because:
    I deleted all customer info 3 in the layout section of the top bar. But it's still showing there. Very strange.
    Maybe I've added it by hand somewhere, but than my memory is very bad. Where can could I find the best way to have done this?
    Thanks,
    Paul
    edited March 2016 Posts: 10,970
    OK I see - you wrote "top menu" but you really mean "top bar". For this one there would have to be made some changes in code. However if you don't need it now then just go to blame\advance\utilities\header.php line~121 and remove this code:
    if($wpml_active){
    //language switcher
    $languages = icl_get_languages('skip_missing=0&orderby=name&order=ASC');
    $lang_html = '';
    $selected_lang = '';
    $current_lang_code = ICL_LANGUAGE_CODE;
    //build languages list
    foreach($languages as $lang){
    if($current_lang_code === $lang['language_code']){
    $selected_lang = ''.$lang['native_name'].'';
    else{
    $lang_html .= ''.$lang['native_name'].'';
    $lang_html .= '';
    echo ''.$selected_lang.$lang_html.'';
  • Yep. Works like a charm.
    Awesome support!
