Full size Images
I´m trying to put a full size images on the home album like in the example of the theme.
I´m trying to hide thumbnails but I can´t do it.
I´m lost in album option...
Can you help me please?
Thanks.
    Ok, I think I discover the solution to achieve full images.
    In the options of the specific album (home album) → Fit images → Fit portrait, isn´t it?
    jdoctor21 said: In the options of the specific album (home album) → Fit images → Fit portrait, isn´t it?
    Almost :-) Fit cover (in same option) is what you are looking for.
    If you want them switched off then use option Enable thumbnails list .
    If you want only to hide them then Show thumbnails/text/none on page load set to None.
    Ok, thanks a lot for your support!!
