Visual Composer not load on page editor
Hi, we created all the site a month ago an everything was ok,but now, updated to the last WP version .... we noticed that visual composer doesn't load the page editor, even starting a new page, the visual composer cannot insert elements... what happened?
    You certainly didn't update the Visual Composer plugin. Now You're using 4.8.0.1 version and the latest version of Adamant(v 1.5.6) is equipped with Visual Composer 4.11.2, which is compatible with WordPress 4.5 +
  • Hi, thank for response. I downloaded the adamant theme but i cannot find how to update the revolution slider plugin, i cannot find it even in the downloaded files. can you help me?
    You should have a notification bar in admin area that informs You about plugins that are available to update. Don't You have such information bar?
  • no i don't...maybe because i didn't put the license values?
    1404 x 665 - 127K
    Which website we are talking about?
  • www.progettocologno.it
    You stil have adamant in 1.5.5 version
    You need 1.5.6 version.
  • oh, i understood why: i had the child theme and until i didn't activate the father theme the update banner want displayed.... now everything ok, i installed the new child theme version too. thank you!
