Theme not compatible with Visual Composer 4.8.1
in Xpert Posts: 3
There seems to be a compatibility issue with Visual Composer 4.8.1 Can you help me get a copy of the original VC plugin that came with the theme or help me fix the compatibility issue? Theme is on version 1.2.3.
Abernathydesign.com
    Hi
    Xpert 1.2.3 is shipped with Visual Composer v 4.11.2.1 and it's located here: ..\wp-content\themes\xpert\inc\plugins\js_composer.zip
    Due to some strange bugs in this plugin You need to update it manually:
    1. take a js_composer.zip package
    2. unzip it - You'll get a 'js_composer' folder
    3. overwrite 'js_composer' folder into '..\wp-content\plugins\' location
    if You get any issues doing this - please send me via private message FTP access credentials.
    please NEVER post here any kind of credentials.
    click my nick and send me Private Message
