Disable Menu Icons
in Chillout Posts: 16
Please help. I am unable to find where to disable the menu icons. These are the icons that appear when you hover over the menu text. eg. Menu shows HOME when you place arrow over HOME a font awesome icon (picture) of a home appears.
    Hi
    please refer to: http://www.apollo13.eu/docs/chillout/#!/installation_update_after_installation
    look at the second picture - it's all explained there.
  • edited May 2016 Posts: 16
    Hi Surgeon,
    Thanks for getting back to me.
    That is very strange I don't see the CSS Classes box in my menu.
    All I have is Navigation Label, Title Attribute, Original:
    Refer to comment below, forgot to add attachment.... sorry :(
    Post edited by omidesign on
    Hi Surgeon,
    Refer to screen shot attached please.
    575 x 672 - 56K
    please refer to http://www.apollo13.eu/docs/chillout/#!/installation_update_after_installation
    First picture shows how to make Navigation Anchors available, but also in this very place You can find 'CSS Classes' checkbox, which in your case is unchecked.
    Hi Srgeon,
    Found it, thank you for you help.
