Menu opener (mobile) - change colour?
in Blame Posts: 3
Hi there,
could you please tell me how to change the colour of the menu opener on mobile devices (and also the thin line on top of the menu)? Seems that default is set to black and if you tap on it, it chnges to some light blue tone (see screenshot) ...
Many thanks
Marko
    Could you post live link so I could see what is affecting it on your site?
    it seems to be a general setting. You can check here:
    www.nanointeractive.com
    www.mtk3-entwicklung.de
    If you look at it on an iPhone the (tapped) menu button is blue and so is the the thin line above the menu ... do you see it? :)
    Cheers
    Marko
    edited May 2016 Posts: 10,970
    This blue comes from "Predefined colors" setting in theme settings http://apollo13.eu/docs/blame/#!/layout_main_settings
    You can switch it to custom color, or some other from menu.
    Excellent, thx!
