Visual composer not working - tried to uninstall and reinstall & update and still not working
in Adamant Posts: 5
The visual composer will not load. The website is www.thedragonsblade.com
Please help
    Hello
    You have the latest version of WordPress 4.5.2, so please update Adamant theme to its latest version 1.5.6, which is equipped with Visual Composer compatible with latest WordPress.
    how do I do that - Adamant is not showing any updates in my dashboard
    I have downloaded from themeforest again and tried to upload into themes section and every time I get this message:
    938 x 247 - 47K
    please refer to: http://www.apollo13.eu/docs/adamant/#!/installation_update
    if this will not help than You''l have to perform a manual update, I can help You, but for this I need credentials to login into admin panel and to FTP access. Send me those only via private message.
    Thank you - I think I have fixed it now
