Dear Air -
Is there a way to customize the mobile responsive menu so that when it's active it covers the entire screen making the user choose something instead of what we see now which can confuse users with smaller phone or older like me with crappy eyesight? I've attached an example of what I'd like to accomplish. Super clean and friendly and maybe just uses the h1 font of the website. If your theme does not natively support this can you provide what I'd need to give a developer to make it for me?
- Jake www.jakemillerphoto.com
As you are probably aware, it is not possible by theme options, but most of this would be available by custom CSS, however you requirements for this are too big for simple forum customization.
You developer should be able to do it without any tips from me, as this is most CSS work, and testing how it will behave in various conditions.
