CF7
in Xpert Posts: 9
I've a issue to fix. When I insert recaptcha field in my CF7 form appear a text field under recaptcha button in frontend. Is there anyone that can help me please?
Thank you
    please provide an url to your website
    and when contact page recharge map often doesn't charge
    I mean after a wrong input in form fields
    ...any other tips?
    I've removed recaptcha from my contact form. I'm going to insert it again when the problem will be fixed (I hope!) by you :)
    please try using Xpert theme with 'Use accordion effect on content blocks?' option disabled.
    Please go to Xpert Options >> General and set 'Use accordion effect on content blocks?' option to 'no'.
    If the problem will not vanish - please provide me login credentials to admin panel. Do it only via private message.
    I tried, it fix the map but not the recaptcha....
  • edited June 2016 Posts: 1,758
    Did you add recaptcha field according to this: http://contactform7.com/recaptcha/ ?
    Post edited by surgeon on
    yes I did
    Ok, finally found that.
    please go to Xpert Options >> Custom Style and paste this definition
    .wpcf7-form textarea.g-recaptcha-response {
      display: none !important;
    It's ok as display on website! thank you
    PS: now, however, if you forget to check it before you send the message, it doesn't advise you to check before send a message...
