It's a small issue, but seems to deter a lot of people from my site. The play button for the Vimeo video on the homepage for the mobile site doesn't work when the phone is tilted horizontally. It works when vertical though. I think a lot of people tilt their phone horizontally before trying to push play and nothing happens.
www.jamesautery.com
That is why there was "hide layout" button that you probably removed. However different settings of album are useful for different scenarios of its use.
Here play button hides under footer so you should change display of album in its settings. Set Fit album to Fully visible.
Fit album was already set to fully visible. What's the best way to remove the footer? I tried #footer { display: none;} in the Hypershot child theme Stylesheet. Still the same issue. Must only be hiding it rather than really removing it?
The hide layout button may be too small and not intuitive for mobile device use in this case. I just want people to be able to push play when my site comes up. Mostly fashion people who don't give websites more than two seconds thought if they can't navigate it.
Thank you for all your help. Love the theme.
I have checked your site and it looks like "fully visible" is not activated. Maybe you have some cache plugin that blocks it?
Putting album in background is not good when you have video there, as controls might be covered by other elements.
