Hi Air,
So I start a new topic for the broken Visual Composer ;-) I'v updated Woocommerce to the latest version and it broke Visual Composer. I'v installed the last VC version, I'v even did it 2 times in order to be sure, but it's still broken... what can I do?
Thanks for your help
Best
Broken - tels me nothing. I need more details and possibly link to your site.
the link of my website is: www.kissthedesign.ch
Thanks in advance for your help :-)
I have seen such problems in past, that Visual Composer was not present and sometimes I had to deactivate and reactivate VC few times, or even switch theme, to make it appear again.
If you like I can take quick look.
If yes, then please send me temporary access to your WordPress so I could check there what is going on? Send it here on forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please attach LINK to topic it applies to.
http://www.kissthedesign.ch/wp/wp-content/plugins/woocommerce/assets/js/chosen/chosen.jquery.min.js
It returns 404 error. I don't see this file in original woocommerce plugin, so it looks that you are right that this plugin
Woocommerce catalog visibility option has error that need to be fixed.
