Hi Team Apollo,
Great theme you provided! Thanks!
I can't solve an issue with Portfolio and Blog anchors.
When I click on any item below (work or post), it loads the homepage with no work or post.
I'll PM you my ID so you can have a look if you need.
Thanks a lot
I can see few extra plugins (SEO and two security-related) you have installed.
Please deactivate them all, then check if problem is present.
Then activate your plugins one by one and check when this problem will emerge again.
You're right, there is a conflict with the plugins. It worls properly now! Good job!
By the way, I have a requested update for setting up a twitter app key. Is it mandatory? How can I stop this update to show?
Thank you
I've just noticed the layout is good only with Chrome browser but I still have issue with IE or TOR browser... ;(
Any idea?
I checked with IE and there was nothing wrong at the first glance.
Sorry to be a client, mistakes happen.
I made 3 screenshots on chrome (that's the good browser) and 3 screenshots on Internet Explorer browser (that's the one that does not work properly) so you can see the differences.
You can see on step 1, I click on the portfolio tab in the menu,
step 2, I click on the first item
step 3, I see the item below the menu. => everything is correct
Now, I do the same 3 steps with Internet Explorer browser.
Step 1, I click on the portfolio tab in the menu,
step 3, I don't see the item. It is the red box you can see, (nice drawing? huh!) So I'm missing the item like in step 3 on Chrome. You can also see the yellow profil tab below the red arrow which it should not appear.
Sorry but I can't be more clear. Otherwise we still can skype and share screen.
Thanks for your support.
Now: this is what I noticed.
If I'm logged in as an admin (using credentials you provided) and browse the public site then all is OK - no matter what browser I use.
If I browse your website while not being logged in - then this issue occurs.
Perhaps you have some kind of cache mechanism built in your hosting service?
