Text color on footer
I have been searching but I think nobody has asked about this (and it is strange). I consider too dark the color of the text on the footer but when I change it to any color it just ignores me. It workd when you change its size, but nor color. I still have access to your demo and it happens the same there.
Parallel to this, I see no difference between the "on dark" and "on light" version of the footer. Nothing changes. Maybe it has to do with the other problem. What should it do?
Thank you.
  • Edit: After some minutes (maybe cache plugin) it changed the color of the copyright message and the footer message but not of the rest of the text on the footer (although it changed its size)
  • Ok, color of every widget has to be changed on itself. You can close this thread, Thanks.
    Hello, and great work on this issue ;-)
